Question about Samsung TV Remote Control
Samsung hitron Remote
I am using samsung hitron 29'' TV. I have lost my original remote now i am using 0026B Remote but with this remote i cant use PRE-Ch,CH-SCAN function.
kindlly let me know is 0026B compatilble with samsung hitron if yes then how shuold i use all the function.if it is not compatible then please provide me compatible remote Detail.
  • Samsung Master
  • 3,604 Answers
Restore Disappeared Data from Samsung Galaxy
Comparing with other data recovery tools, a professional Android data recovery software could be the best one. It is just the reliable and safe one, which is recognized as the No.1 Android data recovery software among multiple Android data recovery tools. It stands out with easy steps to get back disappeared data on Samsung Galaxy, including contacts, text messages, gallery, videos, call logs, calendars, documents, WhatsApp messages, etc,. It allow to scan and preview data before recovery. It has successfully helped over a large number of Android users to recover deleted data, and highly recommended by those users for Android data recovery.
Besides Samsung Galaxy S9 and other Samsung models(Samsung Galaxy S5/S6/S7/S8, Note 4/5/8/9), it compatible with all Android models and tablets, such as, ZTE, OPPO, Google Pixel, Huawei, LG, Lenovo, Motorola, Xiaomi, etc,.
LEARN MORE
Posted on Jan 07, 2019
    New Friend:
If Samsung 00026B remote is compatible with 0026b remote, any one tell me
Posted on Nov 26, 2016
SOURCE:
IrishDruid
  • 2712 Answers
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
  • 6 Answers
SOURCE: want to use samsung remote to control fios box and tv
You can use your own SAMSUNG remote but some of the guide options and dvr buttons may not come across.  If your remote allows you to 'map' the buttons you could circumvent the issue.
Another suggestion would be the universal remote by harmony.  great gadget.  pricey though.
Posted on Apr 28, 2009
  • 6 Answers
SOURCE: remote code for samsung remote
0057, 0087, 0205, 0729, 0793, 0839, 0841, 1087, 3004, 3005, 3008, 3022, 3025, 3026, 3058, 3094, 3127, 3128, 3136, 3137, 3148, 3156, 3172, 3205
rogrrabbit
  • 986 Answers
SOURCE: We lost remote control of samsung TVHD: TX-S3082LUH TV
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/us_electronics_uf4200c_manual.pdf here is the link to the 200B remote manual and the codes are on page 3
Posted on Jun 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
Posted on Nov 01, 2009
How to switch to av without a remote samsung hitron
hi ya
possible ways - they may be a button on the tv, sometime marked source - or a o with arrow through it
or
best bet is to purchase a one for all remote, for tv as you have a large brand these should work fine,
even try a pound shop one, as it a big brand
samsungs direct link is http://www.samsung.com/us/support/owners/product/HL-P5663W
they may be able to sell you an original remote
hope it helps a little best wishes davetech
Dec 08, 2014 | Samsung DLP HL-P5663W 56" TV
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
Just moved and lost my samsung remote. I have direct tv but I'd like to watch movies. Will a universal remote fix my problem? Also, where is the model number on a samsung LCD tv.
The model number (label) is usually located either on the back of the TV, or on the r/hand side of the TV.
To obtain the best from your set, you ideally want the original factory remote. However, some Samsung remotes share the same functions.
Generally, the remotes are specific to each brand, but some brands of remotes have been known to transmit similar frequencies (i.e. Philips & Samsung).
You can only use a Universal remote, if the remote supports the Samsung programming codes (check the remote's user guide to see if Samsung codes are supported).
Cheers,
Sep 04, 2011 | Samsung Televison & Video
I have a Samsung LTN1765X/XAA with the user manual, but I have no remote which is required to go through the menus to set up the TV - I have an ATT 200B universal remote with manual and have gone through...
$29 vs the cost of a new tv is not too bad. i had a similar problem with a Vizio and smart remote. in my case i was able to get support from the remote manufacturer and solved my issues. i didnt have the right code and could only access some of the remote functions until i found the correct code throught the remote manufacturer. not sure how much help you could get from att. i was using a logitech remote. if you cant get help with the codes for the remote, i would opt for the samsung replacement remote.
Dec 24, 2010 | Televison & Video
I have samsung Hitron TV. My remote is not working. I want to buy new Remote. I want code for Remote control
hiThere is nothing special as a code for it. in 6your remote itself you ll see a model code in it. just say that code to the local electronics store you ll get a remote for it. hope it helps
Nov 07, 2010 | Samsung Televison & Video
How do I get the code for my samsung TV remote control?
Please check the bellow link related to your issue:-
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
However these are the Remote Control Codes for different Samsung Models:
With the TV in standby, press the
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
  • With the TV in standby, press the
    {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
    or
    {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
    {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
To exit, simply Power Off the TV.
Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
{DISPLAY}{MENU}{MUTE}{POWER}
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Samsung TV Remote Control
I bought a Samsung Hitron TV on ebay with no remote. I tuned in a universal remote but the menu option says 'Not available' so I can't tune it into my TV.
You may have purchased a defective unit from ebay.
I would contact Samsung customer care, via internet and request generic remote information.
Or you could stop by Radio Shack, Lowes or Home depot . ( Keep your receipt and if it does not work, return it for a refund. )
I would guess, that if you picked this unit up used, and it is defective.
( Most always, people sell items knowing it is defective and take a chance that its too much trouble for you to return it. )
Last of all, you could BING your remote. ie: Generic Samsung Hitron remote.
Also, below, I have a webpage you can download information on remote codes if necessary.
http://irremote.psiloc.com/Show.aspx?d=TV&v=Samsung&m=Hitron&i=24556
Hope this has helped you in your problems with the unit.
Oct 12, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Where can I find remote for Samsung tv model CT3361V
I have bought a Chunghop Rm-139e universal remote on Ebay that works for a Samsung Hitron
Jun 20, 2008 | Samsung TV Remote Control
Samsung hitron
i have an old solo tv - visa electronic remote that i would like to set up for my Hitron tv (samsung), but i lost the my book to help me set it.
Dec 06, 2007 | Samsung TV Remote Control
Samsung TV Remote Control Logo
158 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
