Cell Phones Logo
zouheir Posted on Mar 12, 2013
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2402
Points
Ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
4 Related Answers
tickets1
phoenix kirkham
  • 641 Answers
  • Posted on Aug 11, 2012
SOURCE: samsung gio battery usage hi due to bluetooth, but it's off!!
check and also make shure that the wyfi is turned off..this will also cause high battery usage
Priyesh Vadher
  • 547 Answers
  • Posted on Jun 29, 2012
SOURCE: stuck in odin mode, firmware upgrade encountered an issue. please select recovery mode in kies and try again, that's what on the screen. I have tried evevrything and still nothing, it will not
bou please can you explain in detail your problem, how it started all.so i can you suggest you better solution.
Anonymous
  • Posted on Jul 10, 2012
SOURCE: free unlock codes for samsung galaxy Gio
i need free unlock codes for samsung gio,imei 357823040340782.please e mail [email protected]. or give codes here thanks.
Anonymous
  • 3 Answers
  • Posted on Aug 20, 2012
SOURCE: samsung galaxy 2 won't start, no feedback when charging as well.
Do you have root ?
How do I unlock my Samsung galaxy pro phone
press volume+ and power buttons only when powering on, release the buttons after ~3 sec when you see samsung logo.
1helpful
My samsung cell phone is displaying RAMDUMP MODE(ARM9)and butto0ns not working
Install clockwork mode recovery using odin .. then go into recovery mode.
1helpful
How to log out from gmail in samsung galaxyi gio s5660
go to settings>apps>gmail>clear data and then you should stop sync for gmail in the synchronization settings if this dosent work then you should factory data reset your phone.
Mi samsung exivit 2 stop to work it just don t turn on, in the scrim apear RAMDUMP MODE CAUSE ; FORCE TO UPLOAD.
1. If your mobile is
on, power it off.
2. Press and hold
Power until the
device powers
on, then
immediately
press and hold
Volume Down
(while still
pressing Power).
You will see the
word Start with
an arrow drawn
around it.
3. Press Volume
Down twice to
designate
Recovery mode.
4. Press Power to
restart into
Recovery mode.
You will see an
image of an
Android robot
with a red
exclamation
mark.
5. While holding
down Power,
press Volume Up.
6. Use the volume
keys to scroll to
"wipe data/
factory reset"
and press Power
to select it.
7. Scroll down to
"Yes - erase all
user data" and
press Power to
select it.
2helpful
Preciso de codigo de desbloqueio para Samsung Galaxy Gio GT S5660 - imei - 357331043524907
Hi, To which network has your Samsung Galaxy Gio GT-S5660 been locked to? You can unlock your Samsung galaxy Gio safer and easier using unlock code. You can get the unlock code from www.wickedunlock.com/samsung-gt-s5660-galaxy-gio/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR SAMSUNG GALAXY GIO GT-S5660
1 - Switch ON your Samsung GT-S5660 Galaxy GIO with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Samsung gio unlock
Hi free unlock code are un trustable many times .I recommend you to visitOnlinegsmunlock.com to unlock your Samsung Gio mobile from network lock .Here they ask you the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
2answers
Free unlock codes for samsung galaxy Gio
Free codes does not work some times..So better you will get the code from http://www.mobileunlocksolutions.com/ .It helps to unlock your samsung mobile easily.
I have an older desktop Sony Vaio and when you start it, the pentium four screen comes up then nothing happens. I did the F8 thing to get it to try to start in safe mode and screen that is listing a bunch...
That is the boot log - after the drivers it should load the basic user files. If it gets stuck there then those files have been corrupted. There is only one thing left to do - you must reinstall Windows using the recovery cd that came with the pc when you bought it.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
