remove the toner/drums and transfer belt. on the right side is the reg rollers. there is a black arm and sensor the detects the paper weight etc there. that will control the paper sense errors, make sure it moves freeley, clear of paper, dust etc.
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
This means there is osmething in the memory that is corupted or the memory inside has gone bad, if you found this information helpful please rate it Fixya, thanks for allowing me to answer your free question today.
let me know your error codes, i may be able to asist....
disconnect the power cord, open back panel(hinged door and connecting panel(2 screws). check the security of all the connectors on the 2 main circuit boards.
also on the RH board, pull out and reinsert the memory chipsets, to make sure they have good contact..
