I pressed all wash cycle buttons, unplugged the machine and repowered it, but the control lock light stays on. I assume, that the control lock beeing on hinders the machine to start. Am I correct? What to do to switch the lock off?
There is a Control Lock which locks all the control buttons, so the dishwasher cannot be started. It is enabled by pressing and holding the lock button for about 3 seconds. To disable, press and hold the lock button until the light goes out. A single beep will be heard when the feature is turned on.
There is also a Keylock feature which locks the drawer shut and disables all the controls so the dishwasher cannot be opened or started. It is enabled by pressing and holding the lock button for about 5 seconds. To disable, press and hold the lock button until the lock light goes out. Two beeps will be heard when the feature is turned on.
Both these functions are safety features that enable the consumer to lock the dishwasher controls to prevent children from inadvertently starting the appliance.
These instructions are on page 12 of your owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com. Just go to the site and type in your number under the "Manuals" link. These manuals are available in .pdf (Adobe) format that you can download or print for FREE.
(posted by Jeff Rockwell)
http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: ge triton xl dishwasher
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
