Re: maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Your camera only can use SD cards. The SDHC is a newer generation of SD cards, that need a different protocol you access the files. The newest version is the SDXC version.
SD cards never exceed 4 Gbyte. The SDHC never are bigger than 32 GD and the SDXC are over 32 GByte.
When you try to buy a SD card, the biggest you will find will be 2 GByte. I own 2 SD cards that have 4 GByte, but even I can't find them on the net any more.
The cards are from Platinum. But I even can't guaranty you the 4Gbyte will work in your camera.
Some firms used to bring out new firmware, as soon as the SDHC cards came out. I succeeded to update my TomTom to SDHC and the old thing now even accepts 16 GByte cards. But Canon did not offer an upgrade for the V550, so you stay stuck to the normal SD cards.
According to the specs on Canon's web site, the IXUS 700 works with SD cards, not SDHC cards. SD cards are limited to 2GB in size (there are rare 4GB SD cards, but they tend not to work in SD devices).
Of course, it's your call as to how definitive any manufacturer's web site touting their product might be.
Hi, I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig. If you want the camera to take a card over 2 gig then you are stuck standard SD cards. The other camera does support the card because it's a higher model.
you need an sd card and you should be able to put in at least 2gb card maybe more. any band of sd card is fine but i suggest sandisk they are pretty good
