Computers & Internet Logo
Posted on Feb 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Product Assistant asks for disk that HP didn't furnish
Every time I boot my computer a window appears trying to install ''HP Product Assistant'' and asking for me to insert a disk. No disks were provided when I bought this Compaq Desktop with Vista Premium. What really bugs me is that it continues to try and install and does so throughout the day seemingly on a random basis. How can I disable this ******. HP has been zero help.
  • 3 more comments
  • dcbvirginia Feb 25, 2009
    Thanks jell587 but it didn't work. Two things: the exe file you list is not found in c:\program files\hp\digital imaging\product assistant\bin\
    Also when I run HP Update it does not list product assistant as an option to download.
    Since the .exe file wasn't there, I can understand why it kept trying to install something it didn't have and for which I didn't have a disk.
    Where can I down load the "Product Assistant" program to install it. I certainly cannot find it on the HP site.
    Thanks abain but....
    There is no HPWuSchd2 under the startup tab. There is a
    HPWuSched A... there.
    I am downloading the lastest software for my printer BUT I don't believe the problem is with "uninstalling" or "deactivating" Product Assistant. Rather, it keeps trying to "install' it and cannot find the proper ".exe" file to do so.
    IT was unchecked. I am going to try to reinstall the printer update and see if that does it. Thanks for all your suggestions.
    This is my second HP computer and I won't buy another one.
  • qt57695 Apr 22, 2009
    Hi Jell587,
    I have the same problem, tried all your suggestion, but problem is still there...
    Can you give me further advice?
    Thank you
    Andrea
    UK
  • GmanJoe May 11, 2010
    Do you want to actually install this software or just stop it from bothering you?
Anonymous
Level 3:
  • Master 447 Answers
  • Posted on Feb 23, 2009
Anonymous
Master
Level 3:
Answers
447
Questions
0
Helped
226748
Points
1506
Here is the solution as posted on the HP website. Good luck!
  • 1 more comment
  • Anonymous Feb 25, 2009
    Let's try this...
    Start + Run + msconfig go to "startup" tab and uncheck this entry:
    HPWuSchd2 and click "apply" (this entry may be a little different than typed)
    You'll be prompted to restart the machine and you will receive a dialog box upon reboot which you should check the do not show me this dialog box again and hit ok. If all goes well the error should go away, otherwise read on about a second solution to this...
    You may also remove the HP assistant by:
    If possible uninstall the printer software from Add/Remove Programs first.
    Download and reinstall the latest driver but reply "no" to extended capabilities during the install process.
    Post back with your results...
    Uncheck the application that you found in the startup. From what I've read It is a problem with that utility.
    Sorry you've had to go thru all of this (as I'm sure HP is, it doesn't exactly build a good customer experience).
    The HP Product Assistant is essentially an app that runs resident in memory to help with HP scanners and printers. By choosing no extras during install the assistant should either be disabled or should be much less intrusive to the end user.
    Again, good luck with your problem, hopefully we've isolated it...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5229
Points
I've gone through the deletion of the printer programs and reinstall from the original disc, but the end process is to reboot my computer. The Product Assistant Error 2718 window prevents the close down. What should I do next?
How to parition the harddrive for windows
If You Have Problems Creating a Partition If you have problems creating a Windows partition, check the following: * The disk must be a single partition, formatted as Mac OS Extended (Journaled). If the disk already has more than one partition, you must repartition it. * The disk must be an internal disk. You cannot use Boot Camp Assistant to install Windows on an external disk. * If a dialog appears saying "The disk cannot be partitioned because verification failed," try repairing the disk using Disk Utility and opening Boot Camp Assistant again. If that doesn't work, back up all the information on your computer, start up from your Mac OS X installation disc, and erase the disk using Disk Utility. Restore the information to your computer from the backup and try opening Boot Camp Assistant again.
How do i get rid of hp product assistant asking me for a disk which i do not have cant stop it trying to install all the time
To get rid of hp product assistant follow these steps:
Click on start then click on run (for XP).
(If u have vista them use the search box which appears when u click on start.)
under run type msconfig and then click on ok. you will get the system configration utility.
At the top right you will get a option that will say startup click on that you will get the list of startup items uncheck the hp product assistant then click on apply and then on ok restart the computer.
That should do it for you.
Hp producy assistant with c4480 software. how to stop the computer trying to instal this software each time you restart
Remove the printer software driver and software completely. Install this driver only if you do not want the product assistant. Click on the link below to start downloading the driver:
HP C4480 Printer Driver (40 MB)
Other precautions:
  1. Disconnect your printer from your pc and connect when the driver installation asks you to connect it.
  2. You will need to perform this installation from an administrator account.
This driver is for Windows XP. For drivers for other Windows editions please click on the link below:
Driver Page
1helpful
2answers
HP Product Assistant disk
go online to Hp webpage, download the driver and install it. it will fix your problem.
Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
1helpful
Pop up window upon booting computer
Hi Barbara,
I recommend you to visit the below web link and follow the instructions provided in the document to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631295&cc=us&lc=en&dlc=en
This should resolve your issue. If not reply for further assistance.
1helpful
HP product assistant
I had a similar problem on my desktop Pavilion. This program is just sitting in memory and checking for updates. If your are not worried about getting updates then you can turn it off.
In the RUN box type MSCONFIG and the screen below will appear. Go to the Startup tab and un-check the box for "HPWuSchd2". Click OK to exit. You will need to reboot for this to take effect. (You can always turn it back on if any problems arise).
TO REMOVE ' HP PRODUCT ASSISTANT...DO THE FOILLOWING:
DOWNLOAD WINDOWS INSTALLER CLEAN-UP UTILITY FROM ; http://support.microsoft.com/kb/290301 and save it to your computer. An "icon" will appear on your desktop....msicuu2....right click on the icon and click "open"....a window will open with a list of programs on your computer..............I found the "HP PRODUCT ASSISTANT" on the bottom of the list. ....highlite it and select delete.
This should definitely work.
On startup I get a windows installer message that my HP Product Assistant is needing me to insert a disk. I have had this computer for 3 years and this just started. It is interrupting downloads, etc.
You must have a HP Printer. HP Product Assistant is not a necessary program.
Go to Start > Run. Type msconfig in the run box. Click on the startup tab. See if there is an entry for HP Assistant. If there is un-check the box next to it. Click apply then OK. It will ask you to restart. Restart and see what happens.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
5helpful
2answers
I have problem with my hp laptop, when ever i restart the system it is asking insert the hp product assistant disc and then click ok to install, i dont have any other disc other than the one which comes along with printer. please kindly let me how to solve this........
thanks
kishore
Grand Canyon Tech
Grand Canyon Tech
