I have a Samsung Galaxy S3. When I tried to reset the pin for the Sim Card, I got an error when I input the current pin. I'm down to 1 more try before being locked out and absolutely need to avoid that from happening. Is there a master password that wouldn't have been reset when I initially set my custom password for the Sim card. Thanks. Regards, Mark Morrison NYMarkM@ aol.com OR ny.mark.morrison@gmail,.com
SOURCE: Sim Lock
did u try this one * 2 7 6 7 * 3 8 5 5 # it removes simlock but with all the pictures n music u had on the cell along with phonebook contacts saved on the phone
SOURCE: SIM UNLOCK CODE
*2767*688# not working with my E900 ,
Error = Incorrect entry
may be it worked on ur cell not mine ... anything updated about rest your SIM lock ? :(
E900
SOURCE: PHONE UNLOCK
Unlocking
the E900 is easy..
This phone is fully supported by the SRS server.. More than 2000 phones are already unlocked by this system
you only need to connect your orriginal data-cable to the computer. run the unlock client, login and press the unlock button..
wait 15 seconds.. and youre done..
more info: http://www.UnlockSamsungOnline.nl/eng
Hope my info solves your problem.....
SOURCE: Unlock LG KG800 Chocolate - Pleease help me !!!
This parts 3,4,5 wont work on Virgin Media Locked Handsets.
4. Type 2945#*#
5. ENG. Mode menu should appear
6. Go Down to Factory Reset Select it
If you have a Virgin Media Phone they will activate the SIM lock again on startup if you try this on an LG KG800 Chocolate handset
With
the phone in standby, enter 2945#*7101# this then search will activate
the extra option (7) SIM Locks under the security menu
Go in as
normal to the settings menu you will now see option (7) select it and
then select (1) Service Provider then select (1) Deactivate slect this
and enter your SPCK code you will need to get this code from Virgin
costs £15 or the Internet if you are lucky or use an LG IMEI Unlocker code creator be carefull there are losts around with trojans and spyware bundled inside.
SOURCE: sim network unlock pin for samsung galaxy s3
You can unlock it by codes (by IMEI officia unlock codes) or you can unlock it by cable. Both are available from http://www.unlocksamsungonline.com/unlocksamsung/I9300
This website is a trustable resource and in operation since 2006.
Method 1:
1 - Switch ON your Samsung SGH-A887 Solstice with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A887 Solstice will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A887 Solstice shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A887 Solstice .
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A887 Solstice is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A887 Solstice .
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-A887 Solstice .
Each Samsung SGH-A887 Solstice mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A887 Solstice mobile phone using the form above.
