You cannot bypass the sensors but you can try reversing their position so that the sun isn't hitting the receiving unit. You can also move them back from the door or use something like the tube inside a roll of toilet tissue to shade the lens.
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
SOURCE: raynor navigator garage door opener won't work in bright sunshine
WOW I NEED TO RAISE MY RATES!!
I DON'T KNOW THE RAYNOR PRODUCT. HOWEVER, WITH MOST OTHER BRANDS THE PROBLEM YOU DESCRIBE CAN BE SOLVED BY SWAPING THE POSITION OF THE SENDING RECIEVING EYES THUS GETTING THE ONE THAT IS BEING AFFECTED IN THE SHADE
HOPE THIS HELPS
