GE WSXH208A Front Load Washer Logo
Posted on Feb 23, 2009
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been cleaned, unit unplugged and then plugged back in, that did not fix it. any help greatly appreciated.
  • stubbs1759 Apr 26, 2009
    Start button and power button light up but machine will not start
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2656
Points
No power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
GE front load washer model WCVH6260HWW unlock light stays on, machine won't run
Possibly need a new latch assembly per the suggestions at the link below:
https://www.repairclinic.com/PartDetail/Door-Lock/WH10X10006/1168668
https://www.justanswer.com/appliance/38tio-front-load-washer-reads-door-locked-model-xxxxx-when.html
Question asked many years ago:
3/11/2010
Appliance Technician: Tyler Z.
You will need to remove the lower front panel. There are 3 screws along the bottom. Remove these screws and remove the panel. Next, pull the plastic pull tab on the bottom of the latch assembly to manually unlock the door latch and then shut the door. Then start a cycle and cycle it to see if it will unlock on it's own. If not then you need to replace yoru door latch assembly. Here is a link to the part.
CLICK HERE
Tyler Z., Appliance Doc
Category: Appliance
Satisfied Customers: 87,538
Experience: 9+ years being an appliance technician with factory training.
We tried this and it did not release...is there anything else we can do?
not really unfortunately, you can try holding the door switch button in and try to start and cycle a cycle but I'm not sure that will work either, it sounds like you might just need a new latch assembly.
Does the latch have an actuater that would buzz or make a weird noise during a cycle?
not really no.
Front Load washer reads door locked model wcvh6260hww when
2answers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
WBVH5200J3WW GE front load washer won\'t start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
Have you been able to check that the pump does actually work when it's supposed to?
Here are my A to Z (sorry!) guidance notes for checking both the drain motor filter and the drain motor. Please note the last paragraph ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
I bought a GE front load washer last year model # WCVH6260HWW now I'm having problems with it. It keeps shutting off during a load. I push the Start/Pause button to get it going again, sometimes 3 or 4...
I have the same problem, and I believe it is because the filter is full. I'm tracking down the repair process now.
PUMP FILTER CABINET, COVER & TOP PANEL 285 WH23X10029 $68.00
I've downloaded the exploded view from GE.
1helpful
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
