SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Usually the yellow is for ignition switched-red is permanent +...;)
SOURCE: Need Wiring Diagram For a Clarion DB245
You can download the user manual here, which includes a simple schematic for the wiring color code:
http://safemanuals.com/user-guide-instructions-owner-manual/CLARION/DB245%20INSTALL-_E
SOURCE: WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
