Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Feb 23, 2009
In minolta bizhub 350 pc drum change
Plz change
pc drum
  • elaineprejea Mar 31, 2009
    Please chang PC Drum on Bizhub 200
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3869
Points
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
  • xolisile
    xolisile Jan 16, 2014
    what if the machine say pls change pc drum what is that
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Konica minolta bizhub 6oo Plz wait warming up is showing plz tell me ho to fix this.
Check yout waste toner container. If it's full you should clear it or change it. Or maybe the problem is in some sensor, probably temperature senor on fuser.
Change pc drum
Press bediener - details - stop 00 - stop 01 - enter 00000000 then touch end. Go to Counter- Counter Reset (higlight the six box) - function - f8 - press the start key (wait) go back to counter - pm - highlight ic life or pc life - press cancel button.
Hope it can help you.
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
1helpful
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
1helpful
2answers
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
5helpful
4answers
Konica Bizhub Password Reset
You can try the default admin password which is 12345678
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
