NO TENGO EL CONTROL Y QUIERO PROGRAMARLA CON UN CONTROL UNIVERSAL STEREN RM-13
SOURCE: Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
Hope this helps
SOURCE: I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
SOURCE: dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
SOURCE: replace remote for disney princes p1310atv tv?
Look on the back of the TV or in the back of the manual and you'll see the name of the company that manufactured and/or distributed the TV, or you may find a telephone number listed in the manual. You must contact the manufacturer to find a replacement remote for that TV. Universal remotes don't work because that set is actually made by a small company that doesn't communicate with universal remote makers.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: I have a 13
Tries the website 1-800-Remotes Factory Original.Get the same remote or exact remote to the original.
