E8 code when washer tries to get past the fill point, wont start washing or spinning but will drain, on front loader daewoo dwd-f1221....HELP desperate for someone to help solve, the powers that be dont seem to have any idea!
E3 CODE WHAT MEANS
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
It could be the pressure sensor. If if never detects that there is enough water then it will never do anything else. The pressure sensor has an air small air hose that goes to a hollow, usually plastic cylinder that measures the pressure. Make sure the hose is securely attached on both ends. By the way, there should be a wiring diagram in the bottom of the unit for "service" point of view, but if you can follow a simple print you can read this. One end of the hose goes to a small electronic...sort of module...it has a cylinoid that will allow 115VAC to pass through or not. Generally, if it is not passing 115vac then it does not thing there is enough water in the drum yet. If you have a multimeter you could check the wires for 115 with the drum empty and full. If the 115 goes on and off then it gets worse because it is the main board. Hope that helps.
The E8 error code has a simple fix.. change the carbon brushes, I had the problem and I do every 12 months or so, I make brushes at work (Mersen) and was able to manufacture some from grade Eg300 H, and get 2 spare, they cost around ZAR 150.00 around 10 USD.two screw to take the brush holder off the motor(tilt the machine on its side, against the wall) and work from the bottom of the machine.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
not a DW500M Top Loader, is a DWD-F1221 Front Load.
I have Daewoo DWD-F1021 and it also give E8 code after filling with water. I have only had this machine for 3 years and this is the fifth time it has bee to mechanics for repair, different problems each time.
