Televison & Video Logo
anthony Posted on Mar 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power power does not come on. Cable is working, as I tried it on another device
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Mar 10, 2013
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367269
Points
2185
Replace the faulty power supply @ www.shopjimmy.com
My Numark NS7 does not turn on.
If you're hearing a beeping sound when you press the power button but nothing turns on, it's possible that the device is experiencing a power issue. Here are a few troubleshooting steps you can try:
  1. Check the power cable: Make sure the power cable is securely plugged into both the NS7 and a working electrical outlet. If you have another power cable, try using that to see if it makes a difference.
  2. Reset the device: Try resetting the device by unplugging it from the power source and leaving it unplugged for a few minutes. Then plug it back in and try turning it on again.
  3. Check the power supply: If you're using an external power supply, make sure it's providing the correct voltage and amperage. You may need to replace the power supply if it's not working properly.
  4. Check the internal fuse: If the NS7 still won't turn on, it's possible that the internal fuse has blown. Unfortunately, the fuse on the NS7 is not user-replaceable, so you'll need to contact Numark's customer support for assistance with a repair or replacement.
If none of these steps work, it's possible that there's a more serious hardware issue with the device. In that case, your best bet is to contact Numark's customer support for further assistance.
2answers
My phone is not working, Cannot turn it on or charge battery.
Fix an Android device that won't charge or turn on If your Android phone or tablet isn't starting, won't turn on, has a black or blank screen or turns on but immediately turns off, try these steps to fix the issue.
First, try holding down your device's power button for five to seven seconds. This usually restarts a device.
Step 1: Troubleshoot your cable, charger, wall socket & case
  1. Use the charger and cable that came with your device. To check that the charger and cable are working, try them with another device.
  2. Check that the cable is securely connected to the charger and to your device. Check that there's nothing in your device's port, such as dust or lint.
  3. Plug the charger into a wall socket. To check that the outlet is working, plug in something else, like a lamp.
  4. Check that no accessories, such as cases or battery packs, cover your device's sensors or press its buttons.
Step 2: Troubleshoot your battery charge Within one minute after you've plugged in your Android device with a working cable, charger and wall socket:
  • If you see a battery icon, your phone is powered off and is charging. You can restart right away.
  • If you see a red light, your battery is fully discharged. If the red light is flashing, there isn't enough power to turn on. Charge your phone for at least 30 minutes before restarting.
To restart your phone, press and hold the power button for a few seconds. Then, on your screen, tap Restart . (If you don't see 'Restart', press and hold the power button for about 30 seconds, until your phone restarts.)
Step 3: Troubleshoot your screen If you don't see a battery icon or red light after you plug in your Android device, the issue could be with your screen.
  1. Press the power button for about 30 seconds.
  2. Wait about 2 minutes.
  3. Make your phone ring. You can call it from another phone or use Find My Device.
Mar 10, 2019 • Cell Phones
My pc wont continue booting because of usb overload
what makes you think its usb overload ?
Check your computer's power cable and the power cables to any devices connected to the computer. Make sure all cables are firmly plugged into electrical outlets and into the computer and other devices. If you have an extra power cable for your computer, swap it in to see if your computer's power cable is the problem. Remove your computer's battery, if it is a laptop, and connect the computer to a electrical outlet to see if it will start up. Sometimes a discharged battery will prevent a laptop from powering up. If your laptop still won't power up, remove the power cable, replace the battery and try to run the computer off battery power. Unplug your computer and plug a lamp or radio into the same electrical outlet and see if that device works.
If the lamp or radio doesn't work, the outlet is the problem. Unplug your computer and open your computer's case, if it is a desktop system. Look for loose cables, cards and connections and attach them firmly. Blow out any dust with a can of compressed air. Also, check your computer's memory chips to make sure they are all plugged in and seated properly. Close the case once you are done and plug in the computer. Disconnect any USB devices connected to your computer and try to power up the system. Sometimes a USB device not connected properly will stop a computer system from powering on. Disconnect any new devices recently added to your system. Sometimes new devices will conflict with other hardware within your computer and cause an overload on your computer's power supply. Disconnect any other devices connected to your computer such as the keyboard, mouse, monitor, printer or scanner and plug your computer into a electrical outlet by itself. Check to see if the computer works. If does work, shut it down and connect just one device, such as the monitor. Turn on the computer and monitor and see if everything works. Continue connecting devices until you find the one that is stopping your entire system from powering up. Hope it helps.
b>
I get a weak or no signal on HDMI only (all other inputs work fine). Made sure the cable box was working fine, tried a new HDMI cable and still nothing. Any suggestions?
Was it working before? HDMI is a weak signal by nature, so longer runs may not be possible. How far are you going (how long is the cable)? Are you running this HDMI cable by many other cables or perhaps in the presence of an electrically noisy device such as an electric motor? Also, make sure if you are trying to hook up a computer or any device not usually meant for use with televisions that it is HDCP compliant. What is it you are trying to hook up? Have you tried other devices? With the same cables? You should also be sure both devices are powered down after the connection is made and then powered on first the television and then the other device. If that does not work, power both down again and power the device first and then the television. HDMI is very picky about many things. You may also have to check if your television set has a software update at the Samsung website. Another thing is that the output device may need you to change it to output to HDMI in the menu. Try hooking up another television with it and then try the other. Post back if you're still having trouble. Good luck.
3answers
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
I can not get my Garman Nuvi 260 to come on.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on.
Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on. It is a very tiny button and hard to see. So look carefully!!
4helpful
2answers
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
The device should power on. Notes:
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
Aspire 3684 orbicam not working
Please check in device manager, is it there ?
it's supposed to be under imaging device.
If it isnot there, it's mean it's hardware, it can be orbicam cable or orbicam itself is bad.
In this case, try to reseat the orbicam cable, it's beside power button, you need to open the power cover (power cover is long cover where the power button reside), you just need to remove 2 scews on power cover, it's in lcd hinges. there are 2 cable beside power button, the camera cable is the cable that come from lcd, not from uppercase.
if your orbicam is in the device manager, try to re-install orbicam software. if you don't have orbicam software, you can download it from www.acerpanam.com.
I hope this will help you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
