Tray B of RCA CD burner does not recognize any CD and does not record
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Since these are candidates for the trash heap now, you have little to lose by trying to clean the the lens of the reader. Lightly dampen the end of a Q-Tip (cotton swab on a stick) with glass cleaner or ammonia. Blot the swab on a paper towel to remove excess cleaner and then access the glass lens of the CD player with the power off. *Gently* wipe the swab over the surface of the lens. The mechanism that holds the lens in place is pretty delicate, so go EASY.
Once done, power up & see if the player can read the disks.
THE PLAYER READS DISK AND RECORD ONE SONG AND GOES TO RECOVER OR BUSY
Same problem here !
I, too, am "stuck" (no repair shops) with the same problem...and..I have TWO of these pieces of JUNK...(Made In China - for RCA). Ya gotta love Chinese QUALITY! Good luck...from: Middleman
I have the same problem with my machine. Overall I have been pleased with this machine. It has done everything I needed it for. I have had it a while and need the solution to tray B. Someone help.
