Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
