Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
tried to get channels would only give me on and the viedo shows blue screen other channels shows lock on them dont have a remote friend gave to me dont no code
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B as well as locking each of the EXT inputs, so you should confirm what is locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position Or . Depending on which remote is being used Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT buttons check each channel and input to establish which channels and inputs are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option). The screen will change to show the channel lock System Menu. This screen will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5 OR: IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show the selected antenna and channel or input. The display is superimposed over the picture. This display will indicate that the channel or input is either locked or unlocked. In the lower middle will be instructions to use the 10-key pad or SCAN buttons to select the desired channels (or the INPUT button to change antennas or select the EXT inputs). At the bottom of the screen will be instructions on how to change the current LOCK status (if unlocked use the ENTER button to lock, or if locked use the CANCEL button to unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111) and then press the ENTER button.
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are locked, or, use the INPUT button to select the external inputs that are locked.
7. At each locked channel or input press the CANCEL button. The screen will indicate that the channel or input is either locked or unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
