Televison & Video Logo
neil mcphee Posted on Mar 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 37 inch clarity lcd tv screen has cut out and wont come back on but i still have sound
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Mar 10, 2013
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367422
Points
2185
Sounds like a bad backlight or inverter board!
5 Related Answers
Anonymous
  • 61 Answers
  • Posted on Dec 12, 2008
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
David Low
  • 458 Answers
  • Posted on Mar 24, 2009
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Nov 05, 2009
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Anonymous
  • 563 Answers
  • Posted on Jan 11, 2010
SOURCE: black shadow on screen vizio 37 in lcd hdtv
There is a part inside the TV that needs to be replaced. If the TV is under warranty—whether the original warranty from the manufacture or an extended warranty purchased with the TV—call the company providing the warranty coverage and they will arrange to have your TV repaired at little, or no cost to you.
Since some brands will pay for your repair even if you're out of warranty, especially if they've heard of your problem before and it's a known issue. You should always contact the manufacture first for your full range of options. If they're willing to fix the TV for free, or at a reduced cost to you, let them!
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the TV yourself. Purchase the service manual from the manufacture to get started. However, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you decide to pay for out of warranty repair by a professional repair shop, the total cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Testimonial: "it was helpful thank you do you happen to know what this part is?"
Anonymous
  • 1961 Answers
  • Posted on Jun 04, 2010
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Samsung Galaxy A14 phone. Trying to connect my phone to my Philips tv model 32PFL5322D. I bought an HDMI cord, connected my phone into tv but got nothing. Now what?
Question edited for clarity and what I think you thought you were saying, except for 'Tv is oler'. Older or OLED?
You don't say WHY you want to connect your phone to your television. This television is VERY basic. The HDMI Ports will be looking for a DVD or Video tape player AV data signal, not a phone.
https://www.usa.philips.com/c-p/32PFL5322D_37/81-cm-32-inch-lcd-integrated-digital
Philips 32PFL5322D/37 Manuals
ManualsLib https://www.manualslib.com > ... > LCD TV
PHILIPS 32PFL5322D/37 Manuals. Manuals and User Guides for PHILIPS 32PFL5322D/37. We have 4 PHILIPS 32PFL5322D/37 manuals available for free PDF download: User ...
WHY I HAVE GOT HARITONZAL LINES ON TOP OF SCREEN ON TOSHIBA LCD 37RV635D
sounds like the same problem as with most screens. it could well be the screen as gone
Blue light flashes on front of tv cannot get set to turn on
my sanyo 37 inch was workin fine put it on the wall now the blue light on the front is flashin like mad screen wont *** on got the clicky sound as if i was turnin it over by the side any ideas ??
2answers
Need olevia 32 inch swcreen
Replacement screens are hard to come by for this model as the copany went out of business and no parts are made. The best way and price on a replacement screen is to watch e-bay and craigs list and buy a whole tv that wont power on and swap LCDs. Also www.RNS-Systems.com has uses LCD screens
2helpful
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
2helpful
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
2helpful
2answers
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
5answers
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
