The treadmill had a clicking/knocking in the front end. I unplugged it over night came back in the next day, plugged it in and there was no power.
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: Trying to fix a 20+ yr.old treadmill (Precor USA
Dear Sir:
I hope you are very well, in union with your family.
Thank you by your request, and I will help you inmediately.
Please follow the next step with very carefully:
Makesure that the surge protector being used is properly grounded(Very Important) and turned on.Check that the treadmill power cord is properly plugged into the surgeprotector.
Checkto see that the key is inserted in the console.
Checkthe circuit breaker on the frame near the power cord. If the reset/off circuitbreaker has tripped, wait 5 minutes and then reset the breaker by pressing theswitch in.
4)Check the circuit braker panel house, and reset.
Static Shock Problems:
Many people face a conundrum when using a treadmill. The problem is that a treadmill has you walk or run in a motion that causes you to build up an electrical charge on your body while you are exercising.
The problem if you are swinging your arms, you are totally isolated from any common ground so the charge just builds and builds and many discharges have been measured above 30,000 volts.
You may say, how in a frost-covered hell can I build up 30,000 volts on my body without killing myself? Good question and it has a good
answer...there is very little amperage. It will pop you good when you do ground and sting but it won't hurt you.
The problem is that it can damage the treadmill's electronics if it is not properly designed and we still see poor designs in this respect
If you don't like getting popped or if your treadmill is shutting down or going crazy, there is a fix. You can ground yourself to keep the electricity from building up on your body.
We now have wrist grounding straps that can be reused and attach to the frame of the treadmill without causing any markings and do not require any permanent modification to your treadmill. You can find them in any online catalog by electronic sales by searching for Grounding Strap.
Thank in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
SOURCE: Parts for a PreCor 9.1 treadmill
go www. precor.com or www. fitnessrepairparts.com or www. treadmillspartszone.com
God bless your
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
HI , Check this link for more details about PRECORE error codes http://electro-medical.blogspot.in/2013/...
