Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
Rapid Heater for Jacuzzi
I just installed an AMIGA PLUS Jacuzzi bathtub that came with a Rapd Heater. When I turn on the jacuzzi, the heater light doesn't come on. I checked to make sure the breakers didn't pop and they didn't. Is the light supposed to go on with the heater is on? (I am assuming yes) When does the heater go on, as soon as the jacuzzi jets are going or does it go on when the water temp starts to drop? I can't find info on how the heater works anywhere.
thanks
  • 125 Answers
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Posted on Feb 24, 2009
SOURCE:
Jacuzzi Amiga motor does not tuen on. Hardly ever used
There are no reset buttons on bath pumps. It may be the motor is bad or the toggle switch is bad.
US Parts Center
Jan 26, 2014 | Jacuzzi Amiga Whirlpool JAC-N888...
Heaters for a jacuzzi
Heaters for jacuzzi bathtubs. Click here for a list of what will work for any bathtub.
Bath Heaters
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Can Jacuzzi Rapid Heat inline heater be installed upside down?
You do not want to install any heater upside down because if any debris gets inside the heater pressure switch while it is running it will NOT shut off once the pump shuts off.
Rod
US Parts Center
888-521-6183
Feb 17, 2013 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Spa issues
Is the spa inground also? If so you need to turn off the filter return at the pump and use the circulation pump only. this is only a best guess as I am unsure of the pump setup.
Jun 18, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Heater pump does not turn on Jacuzzi hot tub 325
You should be getting error messages like flo or FLO2. check the voltage to the pump from the board if power is there the pump is bad and needs replacing
Jun 12, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Feb 21, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
877 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
