Question about LawMate PV-500 LITE Portable DVR
I am unable to record audio using the Button Camera
Recording Audio via the Audio In/Out
If this camera come with a Mic input or audio in put you will need to use a seperate amp. or use internal.
Dec 06, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Panasonic 102b
FOLLOW this steps and fix it. God bless you
Fully charge the Sony digital Handycam. If the camera is not powering on or shutting down during the middle of a shoot, it is due to the battery. If the battery is unable to hold a charge (this occurs after a few years of use) you must replace the lithium-ion batter.
· 2
Press the "Menu" button if no audio is recording on the video camera. Choose the "Record" feature, then select "Audio." Oftentimes the audio comes (or is accidentally turned) off. Select the "On" option and exit out of the menu. Now all future recordings capture audio in addition to video.
· 3 Delete unwanted video files if your hard drive is full. When the internal hard drive is full you receive an error message stating the camcorder is unable to capture more footage. Bring up the "View" option on the camera, then select a video file you no longer want and choose "Delete."
· 4
Turn off the video camera and remove the battery. Wait a few minutes before inserting the battery back into the camera. If the menu or any other internal hardware on the computer is malfunctioning performing this reset corrects the problem.
· 5
Upload the video content from your camera to a computer via FireWire cable instead of USB. When using USB the quality is downgraded as it is unable to support the higher data stream required to upload videos. If you don't have a FireWire port on the computer (it is similar in size to a USB connection, but one size is curved and a "Y" icon is printed next to it) you will have to use the USB connection.
Nov 07, 2013 | Video Cameras
I an trying to use the voice recorder on my iHP-120
Press and hold button on left side with red dot (record)... You will see "stand by"...  Press the lowest button on right side (A-B) over and over until "source" is "int Mic"... when you are ready to record, press the left button w/ the red dot short and quick... recording will begin.  When youre ready to stop recording, press middle button (pic of square on it) on right side... that will stop it.
To find your recording, look in the "record" folder under "Audio"
Mar 10, 2009 | iRiver iHP-120 MP3 Player
Audio recording function cannot be switched ON in menu
Check the recording mode you are using. This option is available on Auto, Scene and Macro modes only. To set this, press Menu/Set button to enter the REC mode menu and select the recording option to set.
Dec 25, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Uploading computer screen to camera
Attaching Sound Memos to images In replay mode (including single replay, index replay and magnifying replay) you can attach sound memos (up to 60 seconds) to an image. The sound data is saved in WAVE format. 1. Select [sound_memo_icon_a70.gif (Sound Memo)] in the [play_icon_small_a70.gif (Replay)] menu.
sound_memo_menu_1_a70.gif sound_memo_icon_a70.gifappears
2. Select the image to which you wish to add a sound memo using the left_arrow.gif or right_arrow.gif button, then press the <SET> button.
sound_memo_menu_2_a70.gif The A/V panel appears.
3. Select [rec_button_a70.gif (Record)] using the left_arrow.gif or right_arrow.gif button, then press the <SET> button.
  • The recording starts and the elapsed time is displayed. Speak towards the microphone of the camera.
  • To stop recording, press the <SET> button. To restart recording press the <SET> button again.
  • You can add as many sound memos as you like until their total time reaches 60 seconds.
Feb 06, 2008 | Canon PowerShot A520 Digital Camera
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Embed audio notes
Since the C-5500 has audio recording capability it is possible to record brief audio notes, which become an embedded part of the image file. Open the MODE MENU and select the CAMERA tab. Toggle right to enter the CAMERA sub-menu and toggle down until you have selected the microphone icon, using the OK/MENU button. Then toggle right, select ON and press the OK/MENU button twice. The sound recording function is now enabled. About .5 seconds after the shutter is released the 4 second recording period will begin recording. You will need to point the microphone on the front of the camera toward the sound source. You can also record and record over audio notes on photos already taken. In the PLAYBACK Mode open the MODE MENU, select the PLAY tab and then select START. Pressing the OK/MENU button will start the 4 second recording period.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
LawMate PV-500 LITE Portable DVR Logo
42 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
