KLH Audiohttps://klhaudio.com > uploads > 2020/12 > Wi...
PDF
You can experiment with different configurations, or even add multiple subwoofers to your system (see diagram). 1. 3. 2. CONNECTING YOUR. SUBWOOFER. Ensure that ...
4 pages
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Hi, I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them. OK http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
On the subwoofer's L&R input, you'll see a tiny "mono" next to the Left input. Hook up your receiver's single sub output to this jack and you're all set.
