Ok The Problem is you need to change that programs permissions so that guest have full access only to that program not the whole computer so the computer when log into the other account doesn't block some of the program functions to do this right click on the program you want then say properties then security then you should see something that say admin user etc... click on user then say edit make sure your log in as admin when doing this the check the box that say full control and now click apply close the other box and your done now the program should function right
hope this help doing the following dose not give standards accounts admin privileges it only gives full control to specific programs so that they work properly with out admin rights
Login With the Administrator Account in Windows XP Professional
Click
the "Start" menu and then click "Log Off."
Click
"Switch User" when the prompt screen opens.
Press
"Ctrl," "Alt" and "Delete."
Click
on "Administrator" when the "Log on to Windows" screen pops
up. Type in the administrator password, if applicable.
Click
"OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and
allow it to continue through its startup process. By default your computer will
simply load directly to the primary user account (usually the administrator
account), but if there are multiple users on the system it will load to the
account login screen. Use the mouse to
click on the administrator account from the list of available accounts to log
on. This step is only necessary if you've customized Windows Vista with more
than one account or you have set the operating system to load the login screen
first. Enter the password
required in the password field to log on to the administrator account. Click the
"OK" or "Log On" button once you have entered the password.
This button may be labeled differently depending on the version of Windows Vista
or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows
Vista environment by clicking on "Start" and then "Log
Off." As soon as you have logged off, you will be returned to the login
screen where you can choose the administrator account from the available list.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
I have the same problem.
Yahoo messenger is working only on the administrator account on my vista ultimate sistem.
None of the other users can use it.
