KENMORE ELITE DISHWASHER LIGHTS FLASHING - SMART WASH, NORMAL WASH, TIMER LIGHT ON, CANCEL DRAIN.
HAD A PROBLEM FEW WEEKS BACK WITH CLEAN LIGHT FLASHING RESET - SERVICE OUT - CLEANED PUMP - NOW THIS.
I have a Kenmore Elite Ultra Wash dishwasher model 665-1312. It will start and run normally until just after the soap dispenser opens. It will wash for another few minutes then stops, cancels itself and flashes the clean light. What can I do to fix it?I have a Kenmore Elite Ultra Wash dishwasher model 665-1312. It will start and run normally until just after the soap dispenser opens. It will wash for another few minutes then stops, cancels itself and flashes the clean light. What can I do to fix it?
AnonymousMar 12, 2014
I have a Kenmore Elite Ultra Wash dishwasher model 665-1312. It will start and wash normally until just after the soap dispenser opens. It will wash for another few minutes then stops; cancels itself and flashes the clean light. What can I do to fix it?I have a Kenmore Elite Ultra Wash dishwasher model 665-1312. It will start and wash normally until just after the soap dispenser opens. It will wash for another few minutes then stops; cancels itself and flashes the clean light. What can I do to fix it?
You can't post conmments that contain an email address.
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Kenmore Elite dishwasher Smart Wash light blinking
Sanitize Blinking Light
Some Kenmore dishwashers have a sanitize feature; when this light blinks, it means the sanitization step failed because the hot water in the dishwasher did not achieve the desired temperature or the final rinse cycle was interrupted.
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Door latch. Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options. Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy.
Cost 360$ pieces 130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
