Speed indicator does not light up at all, while the battery level indicator continually flashes. Chair will not move.
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
SOURCE: Chair has new bateries but barely will crawl when
Contact your retailer and explain this to them. They are in the best position to help you with this matter.
SOURCE: flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
SOURCE: when turned on battery indicator lights flash
The flashes are indicating a problem with the chair. Count the number of flashes and that will tell you the error code and what the problem is ie 4 flashes pause 4 flashes indicate a right motor problem. your users manual should have the error codes in it to explain what each is Hope this helps
SOURCE: pride mobility Jet 3 Ultra
Hi, well as long as it's operating Ok, then we are all good,and perhaps it is something simple, such as there is NO profile, or a Profile hasn't been set, or chosen?
www.pridemobility.com/pdf/...Manuals/US.../US_Jet_3_ultra_om.pdf
above & below, are your manual so you can check settings etc.
www.pridemobility.com/...Manuals/product_owners_manuals.asp
Below is your troubleshooting website How To.
www.pridemobility.com/.../basic_troubleshooting_guides.asp
