Hi - the way to enable code mode is to turn off the radio - then hold down 2&5 & press the on button - this will bring you into the 0000 code mode.
Regards Paul
Hi, so you press 2&5, than "on" button, radio starts to play music and beeps every few seconds, now you input number code i.e. 0123 where you jump to second digit because first is 0? and finaly press 5 to memorize code.
did i get ir right?
My renault does not have stick control near steering wheel.
hi the 4 zeros not coming up then goes off after min
I can’t get zero on this code 0123 5
In my case, I followed the instructions of the first asnwer and the radio turned on and "beeped" every 2 o 3 seconds. After waiting 10 minutes, 0000 apeared on the screen and I introduced the password (http://car-radio-unlock.blogspot.com.es/2011/11/renault-radio-code-calculator.html). Once the password is typed. I had to press to press for a while the button 6 till apeared OTHERS in the screen. You have to repeat this (press 6 for a while till the screen change) untill there's EXIT in the screen. Once the radio is turned on again it sounds perfectly without any beep.
PS: I have a Renault Clio (2001)
Yes the answer is as above but you can also press 5 to finalise the code input.If your radio is not the original that came for the car, pull the radio from the dash and check the radio body.Sometimes the code is left there.Hope this helps also.
The best way to unlock Renault car radio from this type is whit generator available on this page. On the online version you have full guide to complete all process without any issues!
Renault Scenic Radio Code Generator Service Works Online For Free
Hi i have just bought scenic 07 1.5dci my was not going on however following the hold 2 and 5 keys it has came on however bleeps every 4 seconds how do i get rid of this bleeping then radio turns off
Hi my name is michael my grand scenic radio code i cant find my serial no is8200300859to813
i lost my code radio for renault
I have a similar problem except once I have entered the code and pressed button '6' to complete it returns to 0000
Any ideas?
hey, i having the same problem and solution one worked a treat! until...now there is a loud beep which occurs every 5seconds or so while I'm listening to music, bit of a pain! How do i get rid of it?
Hey, I'm having the same problem, but solution 1 worked a treat, thanks. but.... now when I'm listening to music there is a loud beep every couple of seconds! Bit of a pain. How do i get rid of it?
hi mate thats what i am trying to find out
hi its just i cant get the 4 zeros to display first step ok then goes off before the display should come on
