Frigidaire ATF6000ES Front Load Washer Logo
karen Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My frigidaire affinity front load washer ATF6000 will agitate but wont spin
The water drains out but wont go into spin cycle
  • Official Brand Answer 4,342 Answers
  • Posted on Mar 11, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466559
Points
5907
Hi burwellkaren - Is the washer making a humming noise? If so, either the drainage hose or pump is clogged and needs cleaning. If not, then the unit may possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, door lock assembly or something more severe like a damaged tub. I will personally recommend contacting a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Jan 06, 2008
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Anonymous
  • 196 Answers
  • Posted on Nov 12, 2008
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Anonymous
  • Posted on Aug 30, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 21, 2010
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
Anonymous
  • 1554 Answers
  • Posted on Jul 13, 2010
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
tip
Affinity Washer Factory Service Manual
Here is the link to the Factory Repair Manual for your Frigidaire Affinity ATF6000 - 7000 Series Washing Machine.
Frigidaire Affinity Washer Repair Manual
Thanks
2helpful
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
My washer is not spinning. What can I do to fix it?
front load infinity washer will agitate but won't drain and spin at end of cycle; water sits in botton of tub
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
2answers
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
1helpful
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
