Fan sometimes get loud, and fireplace sometimes switches itself off. Why would this happen ? I'm afraid to turn it on now in case of fire.
If it only switches itself off when the heater is turned on, it is most likely an overheat-temp-sensor that is doing it. If you have had the fireplace for over a year, you may want to do a complete clean/vacuum etc of the unit. A decrease in airflow can lead to the temp sensor tripping. If that does not work, you should contact the dealer for service.
SOURCE: Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
SOURCE: Electric Fireplace Insert
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: How to start a gas fire-place
Hi remove bottom cover you will see black knob with off pilot and on , turn knob to pilot push in and hold in press igntion button untill pilot lights hold knob in for 30 secs then release if pilot stays on turn to on postion if not try again ,
SOURCE: I have an electric fire
I just repaired ours and it is quite simple,if it is the same type.First remove the front cover frame, then with a screw driver repove the clip at the top of glass,ease out the glass and lift up to remove.Remove the plastic logs and you look inside and you will see your burnt out lights,remove them, buy the same type and replace them, normally they are standard candleobra light that you can buy at any hardware store.
