I just purchased a 2002 GMC Savanna that has a KEC Mobile Applications tv, model 13bnl/3. This tv doesn't seem to work and we would like to replace it. Need to know how much they cost.
You need to pull the pressure sensor and install a manual test gage, (borrow from Autozone or other chain part store) that is the only way to verify the engine is not loosing oil pressure.
You only need to plug in the Red/White/Yellow plugs. Make sure you plug them into the correct colors on the TV. Most HDTVs have Red/Green/Blue ports. DO NOT use these ones, they are for receiving HD video signals. A lot of HDTVs also have the Red/White/Yellow plugs on the side of the TV (often labeled "Game", maybe something like "Video 3")
The Red/White/Yellow cables are known as RCA cables or Composite cables so look for any ports with those labels as well.
probrem is in the intrument cluster. Most times the body control module has to be re-flashed. I would recommend seeing your GM dealer, before any parts replacement...
My sincere apologies for the delayed response. I am personally going back to answer your unanswered questions. I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
For the 5.0L: Firing Order: 1-8-4-3-6-5-7-2
Cylinders: (back of engine) 8.............7 6.............5 4.............3 2.............1 (front of engine)
pick up a chiltons or hanes rapair manual for your vehicle at your local partys store. most likely, you have to remove one bolt and swivel the caliper assembly upwards.
