Televison & Video Logo
Posted on Mar 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I connect two tv to one television converter box to watch local channels
I can no longer afford cable prices so I went to walmart and bought a converter box I have a flat screen in bedroom then and oldersony in living room is it possible to have them both using one box because the cost was around $75.00 with antenna for the one hook up?
Level 3:
  • Televison & ... Master 6,688 Answers
  • Posted on Mar 08, 2013
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3533069
Points
21745
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
5 Related Answers
Anonymous
  • 137 Answers
  • Posted on Dec 07, 2007
SOURCE: NO SOUND ON NEW TV
What kind of Connection do you have coming from the Dish receiver to Your New Sony Bravia TV. This is very important information.
Best regards
CircuitCity
Anonymous
  • 374 Answers
  • Posted on Oct 16, 2008
SOURCE: CABLE JACK NEEDED
You can try using an rf modulator to convert the coax signal into one that you connect to the tv using RCA jacks. I believe that model has one source on it for AV. Most stores carry these and they are relatively inexpensive.
Anonymous
  • Posted on Apr 10, 2009
SOURCE: Use Visio just for dvds?
(duh)
I will post this answer just in case anyone else out there has this problem.
Press the button on the remote that says AV. The blue screen saying "no signal" disappears and you can watch videos without a server or antenna connection.
Jambam
  • 56 Answers
  • Posted on Apr 18, 2009
SOURCE: unable to receive local channels
According to the manual for the 42LC2D it should be able to receive local channels through a normal analogue antenna connected to the anntenna/cable coax input connector. You can get the manual here http://us.lge.com/download/product/file/1000001586/60PC1D-UE.pdf
3764alan
Alan Spicer
  • 127 Answers
  • Posted on Jul 07, 2009
SOURCE: Philips flat tv. Can't get it to hook up to dish
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
1helpful
Converter Box?
No Sherry. Switch to ASTC or "Air" in the menu, Click Scan. You might need an indoor antenna. A good one is a flat panel type antenna sold at biglots. Can hang this by a window. An indoor amplifier helps. Around $16 at walmart.
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
2helpful
No getting digital reception
With this model tv, if you are using the coaxial connection on the tv to receive local stations you will not get any. The tv is digital, but not the tv tuner. As of June or July 2009 that tv will no longer receive analog channels from local stations as they are now all digital. You need a digital cable converter box to convert the signals to analog. *** This is if only if you are using the coaxial input.***
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
2helpful
3answers
I have a problem, I purchased a Digital TV and it doesn't work
You can get a replacment from the maker of the digital converter. You will need to mail in the old unit but they will send out a replacement
Watching tv and lost all channels
are you located in USA? If yes digital transition had done something but don't worry we are her to help you. a converter can do amazing thinks. buy a converter box from walmart and then all will go well!!!
2helpful
4answers
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
