HTC Touch HD Smartphone Logo
Posted on Feb 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connect to Active Sync using Bluetooth.. Is that possible?
  • jim4il Feb 23, 2009
    Thanks for reply but, am I missing something? There is option for IR, USB, port... but nothing says about Bluetooth in Active Sync, there is no such a choice. When I gave looke automatically the pc does not find the HD and in both HD & PC bluetoth turned discover, good thing they do find each other foe sound, but not AS. Please mor specific if possible.
  • jlitsa Apr 14, 2009
    What about bluetooth sync HTC touch HD ?
Damen Wong
Level 3:
President:
  • Master 1,950 Answers
  • Posted on Feb 23, 2009
Damen Wong
Master
Level 3:
President:
Answers
1950
Questions
0
Helped
1027716
Points
5739
Yes it's possible. In the activesync program, press menu and you should see an option of connect via bluetooth.
1 Related Answer
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Dec 07, 2010
SOURCE: i Mate 8502 Ultimate will
Welcome to Fixya
If the problem just occur recently then you might need to reinstall the activesync software. Try to insert the USB to other USB ports available. Would it be possible if you can provide me the error message that you are getting?
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 • Cell Phones
How to connect to internet via htc s710 to computer
first you need microsoft active sync on your computer, this is for the drivers, then select wireless modem from program menu, option will be usb or bluetooth, select usb now connect phone to computer, it will show htc generic modem found , if driver is not installed it will be in c/program files/active sync.
now next create a dial up connection dialup no is *99# usually and connect.
reply for any feed back
HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
1helpful
2answers
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on [email protected] il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
2answers
Palm TX, Dell 6300 Laptop, can see each other through Bluetooth but will not connect. Want to connect to sync clocks.
Have you checked your hotsync settings and bluetooth settings to make sure that you are using bluetooth sync and not the serial connect. Palm devices can also share LAN/Internet over bluetooth.
4helpful
2answers
Sansung i780 to be used as a USB modem
(I) 1)First pair the PC and your phone of course 2)After pairing, meaning the phone and the pc sees each other, go to your phone and look for the icon "internet sharing". 3)Choose bluetooth pan as you pc connection then press connect. So now your phone is on data connection via gprs, 3g or 3g+ 4) Then go to your pc now and go to My bluetooth places search for Network Access Point and enable it. It will turn green with arrows, meaning it has established a connection.TADA! Now you have internet connection using your i780s
(II) Do you have in your programs or settings a icon called Internet Sharing?
If so please connect to active sync first and then select the internet sharing icon.
Active sync will disconnect and your laptop will start using your phone as the modem.
Wuth
Jul 01, 2008 • Cell Phones
How to connect it to a pc running Win XP
Simply download the active sync from http://www.microsoft.com/windowsmobile/activesync/default.mspx
And use the USB cradle to connect to computer (You can also use Infrared and Bluetooth). As long as active sync is on the computer system will recognize pocket PC automatically
Good Luck
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
