Jewelry Adviser Watches Mens Ingersoll Automatic Pennsylvania White Dial Dual Time Watch Logo
A
Anonymous Posted on Mar 07, 2013
Ingersoll dual face watch battery
How do I change the battery ?
Ingersoll Ottawa in16198k. I just need an owners manual for this watch please?
Question edited for clarity and spelling of Ottawa, capital of the Province of Ontario.
Question moved from Ingersoll Rand Compressors to Watches.
The watch doesn't exist. Are you by any chance in South Africa and this watch was a promotion item from Ingersoll Rand?
https://www.google.com/search?q=ingersoll+ottawa+in16198k
You can find generic instructions based on how many buttons it has, 3, 4, or 5.
https://www.google.com/search?q=3%2C+4%2C+or+5+button+watch+manual
Feb 14, 2023 • Watches
Replace the battery in an ingersoll japan movement
I expect the battery will be where it is to be found in most other watches. Remove the back of the case and the battery should be fairly simple to access.
Oct 21, 2017 • The Watches
2helpful
Fossil AM-3539 The watch has 2 batterys. one operates the changing face the other the watch movement. I replaced both batteries and now the face doesn't change. How do I re-set it?
Please note that many Fossil kaleido watches, especially the sports variety actually have THREE batteries. Two run the animation and one runs the time. The time one lasts much longer, usually a few years, but is smaller and buried a little deeper so you could overlook it if not paying attention. The two kaleido batteries are very visible and usually placed side to side. Pay attention though as for some of the watches those two batteries are set in the same way ( both positive sides up) while others, especially the sports variety have one battery positive side up and the other negative side up. It is important to replace them the same way or the watch will not work
Aug 12, 2011 • Watches
6helpful
4answers
I recently took my fathers ingersoll duo watch to a repair shop to have new batteries installed unfortunately they were unable to separate it and get inside. could you please tell me how to do this.
I wouldn't advise you to do it yourself, as without special tools and knowledge you will just damage that watch. The best way is to type in your browser: watch repairs + your area. You should find plenty of them there. Contact by phone first and explain what sort of watch you do have and what's needed to do. Ask watch repairer on the phone, because only him/her will be able to understand specific needs. Do not explain to manager or just personell - they are useless. When you are satisfied with the answer over the phone, go there and give your watch for whatever it needs.
Jun 02, 2011 • Watches
Wala
As the question is incomplete, there are suggestions: 1. Dual watch is reversible watch where the watch face is on both sides. Each face usually have different design and features. Wearer is wearing two watches at once and can choose which one can be visible. 2. Dual watch can be dual time watch. That means watch has capability of showing time in two different time zones at once.
2answers
I need a replacemnt mesh band for the skagen 281LSS
go to skagen.com they have cheap replacement bands for your watch you can even send it in and they will send it back to you like new.
Duel face watch
I would take go to Wal-Mart. They have virtually every battery and they will change the battery for you as well. If they don't have it then a jewelry store will.
I have a Fossil JR8103 woman watch with leather strap and the face of watch is held on by two silver dots. I can't figure out how to get the face off so I can change the battery. Help!
DONT try to change a watch battery yourself unless you have crystal press to close it and thats if the case back pops off...if it screws on then you need a case wrench to open and close it! Better to seek out a local watch repair business and avoid Walmart! :-P They arent trained to repair watches...Ive fixed a lot of their mistakes!
2answers
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
2answers
Indiana (IU) Fossil Kaleidoscope watch
It has two batteries.  The 2nd one is not obvious.
Top Jewelry Adviser Watches Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Jewelry Adviser Watches Watch Expert? Answer questions, earn points and help others
