Trying to find the memory wire from the the hornes of the 1996 mitsubishi montero
The ignition 2 wire color on a 1996 Honda Accord are White/Black. It is located at the Ignition Switch Harness. --------------------------------------------------------------------------------------
Original Launch X431 Master
SOURCE: what kind of transmission fluid do you put in a Mitsubishi
Automatic: Mitsubishi Diamond SP-III ATF.
Manual: 75W-90, 75W-85W GL4
SOURCE: Replace Spark Plugs on a Mitsubishi Montero Sport 2001
http://www.autozone.com/autozone/repairinfo/common/repairInfoMain.jsp?targetPage=productsHowToInspect&leftNavPage=productsHowTo&pageId=%090900c15280213e6e&subtitle=service
Try to copy and paste this web site. It's for Auto Zone. It will tell you all you need to know about your vehicle.
Good Luck and hope this helps.
SOURCE: Changing transmission filter on Mitsubishi
FIRST YOU HAVE TO UNBOLT THE TRANSMISSION PAN ON THE BOTTOM OF THE TRANSMISSION. THERE WILL BE FLUID IN IT SO BE CAREFUL NO TO SPILL IT. AFTER THE PAN IS OFF YOU WILL SEE THE FILTER ON THE BOTTOM OF THE VALVE BODY. IT MAY BE BOLTED ON AS WELL. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
SOURCE: Mitsubishi Montero Sports will not start...
I HAD THE SAME PROBLEM. I TOOK THE AIR FILTER HOSE OFF THE CARBARATOR AND ADDED CARBARATOR CLEANER. PUT IT BACK ON, AND WORKED. TRY THAT.
