Sometimes the setup procedure might be not right. Check it with an other code. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given. Zenith TVs should synchronize with codes to RCA. Check the number of digit codes, that the TV asks. If it is a three digit one, and you are entering a four digit code, the TV won't synchronize.
Sometime tv is pretty old model the universal codes provided don't works.Try website like Remote.com for more codes to tried or must buy the tv original remote.
SOURCE: codes for a 2000 or 2001 orion tv set using an rca universal remote control
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: LOST MY INSTRUCTION MANUAL FOR MY RCA DIRECTV UNIVERSAL REMOTE
Here's an on-line guide
Here's a codes page (Sylvania 10054, 10030, 10171,10020, 10096, 10381)
SOURCE: rca big button universal remote
Go to: www.rca.com then .... accessories..... (On the left of the page) go to owners manual ..... also check for your code under .... code look up.... if your TV is not listed, use the search feature outlined in the owners manual
SOURCE: rca universal remote control code for a sumishi t.v.
go to this web site for RCA you will find it there http://www.rcaaccessories.com/remotefinder/
