I have obtained a reconditioned Fujitsu-Siemens Scaleo 600 desktop PC. It came without any discs and with the software installed, I'm worried that if any problems arise I will not be able to get the PC back to a working condition. Thanks
I wouldn't worry that you won't get it running without a Recovery Disk.
Just wanted to state that right off the bat.
You can buy a fresh, new Genuine copy of Windows XP, and use it.
Jus sayin'.
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer]
Don't know that much about Fujitsu Support, as to obtaining the Restoration Disk, for THAT computer.
Guess there's only one way to find out, huh?
That apparently would be to choose THE country you are in, as support is country specific.
Looking at this from a USA perspective,
http://www.fujitsu.com/us/contact/
Call 1-888-385-4878
Have to try that tomorrow. It's presently 9:52PM, lol!
No wait! Hold the phone.............
Just called 1-888-385-4878
It's a 24 hour line.
Just talked to the representative on the phone.
I didn't have the Serial Number, naturally; but did get basic information.
The Serial Number is needed for specific information.
[NOTE* Do NOT give out the Serial Number on a worldwide forum.
ONLY give to an authorized Fujitsu representative ]
From what I understand it does depend on the disk you need, and the type of computer..
IF, I understand correctly, the disk (DVD) is $12, plus the shipping and handling.
Sounded like the maximum cost is $28. (USD)
Indicated a 2 to 3 day ship, and sent by Fed Ex.
Best method of course is to just call them yourself.
If I may, would appreciate hearing about how it was, for you to obtain the disk.
Will increase my knowledge.
[A LOT cheaper than a fresh, new Genuine copy of Windows XP, too!
Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: Fujitsu Siemens SCALEO 600 PC - PROBLEM BURNING DVDS
You may be using the incorrect dvd disks either DVD+R or DVD-R
or you might have dual layer DVD disks which you will nedd a Dual layer dvd writer.
Down load of of download.com an easy to easy dvd writing program aas this may help as well.
Hope of some help
J
SOURCE: Specifications for Fujitsu Semiens Scaleo 600 desktop PC.
Visit http://support.ts.fujitsu.com/com/support/manuals.html
Make sure you have your serial number ready to view the manual. Hope this helps
www.mcmsacto.com
SOURCE: fujitsu siemens scaleo 600 desktop just keeps
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
SOURCE: my fujitsu siemens recovery disc won't work
what error message are you getting?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
