All settings for ringing tone and volume are high. i have also tried a master reset but still the same tom
Sounds like your speaker or earpiece could be bad on your phone. Return to your carrier or call customer service from a different phone.
The problem is most likely with the head phone jack if you listen to music with head phones on your cell phone. usually happens when u push it into the jack wrong.i had the same problem. get a heack phone jack and kinda insert it at a angle pushing the sides of the jack on the inside. only reason it rings and other sounds isn't functioning is due to it "thinking" the head phones are plugged in.
SOURCE: sony ericsson z5201
I misplaced my software installer of sony ericsson z520i then i could not download mp3 songs.
SOURCE: my Sony ericsson k800i is not ringing in full volume
I had exactly the same problem and came to a conclusion.
When you are playing in your music player at the same time it's playing use the volume keys on the top of the phone.
I hope this helps
SOURCE: Ring tones, Thems and wall Paper
Call your Phone provider or goto thier website and chat with tech support they should be able to send your files back to your phone
SOURCE: the bluetooth headset is on
this s bcoz of volume settings while calling i guess...u better check the volume settings friend!!!
SOURCE: I can't find where to change ring tone or volume
yes go to menu, settings,personal, profiles pick the profile u r using tap on it pick personalise and pick message alert or ring type hope this helps
