SOURCE: REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in.
While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
SOURCE: Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
SOURCE: PT-47WX53 47 in. Rear Projection HDTV Television
replace the DG board which is the small board which plugs into the A Board ( on the left side looking in rear of the set) The DG is the board which lays flat on top of the A board. You can get the A board and the DG board combined at www.tvrepairworld.com They may sell it seperately if you inquire.
SOURCE: My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
