Vodavi Enhanced Starplus SP-61612 Corded Phone Logo
Posted on Mar 07, 2013
No ring My phone doesn't ring, but I see the line flash.
BrianaWalker
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Mar 07, 2013
BrianaWalker
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
4762
Points
36
It is likely that your internal wiring is faulty. You now have the choice of repairing the wiring yourself or contacting a telephone maintainer, who is likely to charge you unless the wiring is covered by a warranty.
Phone doesn't ring
Switch the ringer on but if you already did that you should plug it in go on that website you mensioned and go to help.
1helpful
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
2helpful
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
We have one incoming line that we don't want to ring. How do we program the Avaya System to stop ringing when a call comes in on that line?
At ext 10 or 11
press feature 00
LEFT intercom
LEFT intercom
Right intercom
enter extension number to change ringing on
the line buttons will light up if you touch the line it will change the flashing and the ring style.
Once done, press feature 00
Repeat for all phones.
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
1helpful
My Panasonic Phone KX-T7630 rings seventeen (17) times before going to voice-mail. Desired amount of rings before going to voice-mail is four (4) to five (5).
This is just for your phone ringing when it's dialed, not for outside lines ringing on your phone.
From your intercom, dial *7104 (CF No Ans) 500 (if that's your VM extension) # That will flash your FWD/DND light to tell you it's forwarded on No Ans. Now on the intercom, dial *71324 The 713 part tells your phone to forward after xx seconds. 24 is about 4 rings. You can adjust the timing using 6 seconds as a ring cycle.
Carl
3helpful
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
We just had a used Meridian phone system installed. Only one of my phones will ring when there is an incoming call. The other phones only indicate that there is a call coming in by the flashing line...
You will need to go into programming and set all the phones to ring.
Log in: Feature **266344, 266344
Scroll to Configuration > Line Access > Enter set number > Scroll to Ringing> Then go to each line and set it to ring.
Top Vodavi Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
