Will insert disc to burn copies but it keeps saying disc error 0207,it will play back. this is a new problem
SOURCE: Won't Read blank disc!!
The wrong speed of DVD is being used. I had the same problem when I bought 16x speed DVDs. The DVD-R120 recorder only records on DVDs that are 8x or lower.
SOURCE: Error 0207
MIRA LO QUE TIENES QUE HACER ES BUSCAR EL MANUAL TECNICO DE ESTE MODELO, NO SEAS WEY
SOURCE: SAMSUNG DVD R120 error EC:0207
Search for the latest firmware for Samsung R120 and download it, burn it to a disc, then put it in the player. Get the latest firmware and you'll be fine.
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
disc read error #0207 can not read nor record
