Re: My dual control sunbeam electric blanket flashes on...
Ours did this when the plug from the controllers to the blanket was half unplugged - but I get could also be a bad element in the blanket. Be safe - get a new one
The cover is held on by two screws underneath the top cover AND double sided stick tape, You have to remove the screws from the handle plastic knob. Also remove large knob for steam control pulling it up . Good luck domshea at aol.com
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem: 1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet. 2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection. 2. Unplug the cord from the actual bedding product itself. 3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete. 4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
The cative likght flash in one side only
It is my sunbeam electric blanket
