Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
Can't change the toilet seat that broke on kohler rialto
  • 3 more comments
  • efafeessff Mar 07, 2009
    I have the same problem. The screw that affixes the seat is being held in place by some sort of nut or sleeve INSIDE the body of the toilet. You cannot access the nut from anywhere outside or inside the toilet - it appears to be in a completely enclosed box within the construction of the toilet itself. Turning the screw counterclockwise just causes the nut within the toilet to turn with the screw - the screw does not loosen. Will I truly have to replace this toilet because Kohler did not engineer an easily replaceable seat?
  • Jim McCard
    Jim McCard Aug 29, 2013
    the toilet seat screws are cmpleatly enclosed in a box toilet system hoe to tighten
  • Anonymous Mar 27, 2014
    Hi there I have a kohler toilet and need to purchase a square toilet seat . Do you know where I could get one?
  • Jim Snow
    Jim Snow Aug 08, 2014
    KOHLER RIALTO TOILET SEAT REPAIR - go to your hardware store and buy a 10-32 well nut (a rubber insert with a brass screw thread inside it) along with a 10-32 phillips head pan head machine screw (preferably stainless to avoid corrosion). Use a small washer that fits inside your new toilet seat base and in five minutes (after you remove the old seat and screw) you are done with a tight fitting $3.96 repair.
  • Jim Snow
If your problem is like mine your toilet seat is loose and swivels when you sit on it. If you try to tighten down the screw it won't tighten. Use instructions above to remove old hardware.
To fix with new hardware
Purchase Hilti brand 3/16" x 2-1/2" Toggler Brand Toggle Bolt (Home Depot sells the kit). Kit comes with 10. You will only need 2. My last repair lasted about 8 years (with new kit = 40 years left or the purchase of a new toilet - whichever comes first). Set comes with 3/16 flat head screws. I recommend purchasing 3/16" 2" round head screws with matching flat washers. Sink Metal Toggler into hole with toggler pointing straight up (it's attached by long plastic legs). As it goes in the hole it opens up. Pull up on the plastic pull rings as tight as you can until the toggler is tight up against the inner porcelain of the bowl (similar to tightening cable ties). Line the seat up with the holes and it's new plastic adapter (that won't slip into the hole courtesy of Hilti). Slide washer underneath round head screw but on top of toilet seat assembly and screw directly into the newly installed toggler which is sunk in bowl/abyss receptacle. Repair should take around 5 minutes.
Posted on Aug 09, 2009
  • Hogwild 2 Aug 10, 2009
    I forgot to mention that once you tighten up the toggler you need to snap off the slack of the plastic legs that now protrude upward past the hole.
  • 24 Answers
Kohler Rialto Toilet seat replacement.
Use dremel to cut off old bolt and allow it to fall into the black abyss that is the genius of Kohler engineering. Enlarge the hole to 3/8. I worked up to that size slowly increasing bit size so as not to crack porcelin. At Home Depot I bought a 1/4 x 20 x20mm "Insert Nut" and a good 2 part epoxy meant for metal and ceramic. Gently tap the Insert nut about 1/2 way into the hole and apply epoxy all the way around. Continue tapping the insert nut until it is flush. Clean off excess epoxy and allow to set. Now attach any standard round toilet seat using the standard 1/4 nut that comes with it. I used a Kohler "Cachet" round toilet seat to replace the Kohler "French Curve" that comes standard with the Rialto. All in all it should take you about 1/2 hour.
Happy Fixing!
Posted on Jul 03, 2009
    Novelist:
  • 152 Answers
If you will observe the rear of the unit, with the lid down, you should see two connecting brackets that are affixed to the hinge of the seat. These have snap down covers that hide the fasteners where the seam can be seen with close inspection, and can be accessed by inserting a fine bladed straight screwdriver in to the seam and lightly prying upward. This will expose the head of the screw or bolt and there should be a vaulted concave under that area at either side that will allow you to access the wing-nut. With the proper tool to turn the screw/bolt (counterclockwise) while grasping the wing-nut will remove the fasteners, thus removing the seat. Replacement is achieved by reversing this process.
Good luck...
Posted on Feb 22, 2009
    New Friend:
I had the same problem. The one piece Kohler toilet did not have any way to access the bottom of the bolts. One of the bolts unscrewed with no problem at all. The 2nd one would not budge. So, I went to Lowes and bought the largest straight slot screwdriver that I could find and also I bought penetrating oil. I first tried the super large screwdriver, but the bolt still would not move. So, then I put the penetrating oil on the bolt. Still no positive results. Then, I held the washer up, scraped under the washer so that the penetrating oil made it to the threads on the bolt and got a pair of vice grips and locked onto the bolt. After an hour the bolt started to turn. I then installed the toilet seat using the original bolts and the job was finally done. It would have never happened if Kohler used plastic bolts instead of metal ones. It is my opinion that Kohler needs to hire some rational engineers so that there is maintenance access when a consumer wants to something as simple as change a toilet seat.
Posted on Apr 07, 2013
    New Friend:
Toto THU651N
Posted on Dec 13, 2013
I had the same problem as TnLes. The Rialto 3386 is a stupid engineering flop. Just got off the phone with "Matt" at Kohler customer service. He gave me the same spell, and run around. I asked for a supervisor on Only to be told they were'nt available. All he did was to condescend me, and he repeated three times.....all one piece toilets were this way ! Grrrrrrrr.....finally he agreed to send it to me for free....but couldn't guarantee I would not have to drill out the screws. Very bad customer service. Anyone should be able to replace a toilet seat without calling a plumber and doing non conventional measures to replace a part. I told him it was an engineering flaw and he disagreed. His treatment of me was to out talk me and condescend, p Robably because I am a woman. He said sites like this get people to call in just to get the repair kit for free. I told him, I was only searching for help from others online since Kohler offered no real advice or answers on how to fix this problem.....duh."... now I have to wait for 7-10 days for this stupid kit....which may or may not work. I am disabled with 4 spine surgeries and my husband is an amputee. We both now have to climb a set of stairs to use a toilet while we wait for this "repair" kit. Let's do the math.....3 toilets x 500.00 + 250.00 for initial installation + 90.00 for new toilet seats + wait for 7-10 days, and may a call to the plumber to drill out the old screws ( 150.00 ) =. Very costly, not to mention a huge waste of my time. I will not be buying Kohler again......American Standard, here I come, :(.
Posted on Aug 08, 2012
  • Mary C Dec 17, 2013
    The new Kohler toilet seat we struggled to install has broken after one year of use. Buyers beware these don\'t last as long as the original ones.
  • Mary C Aug 30, 2014
    All new toilets are now made with plastic attachments to allow for a quick replacement. No more internal bolts that can not be removed like before. Amazing to me that they do not willingly help former customers with this problem. By not helping former customers they are losing dollars to other toilet manufacturers. Also they need to get rid of the bad people at their customer service help desk....that was the worst I have ever experienced, ever.
I have just replaced the toilet seat on my Rialto with a Kohler Brevia. It was VERY hard getting the old one off. I had to prise the hinges up while unscrewing it. I got one off completely, but the other broke and I didn't want to spend $47 on the kit from Kohler. I used a 3/16" short hollow wall anchor from Bulldog (AN-252). I wound some PTFE thread seal tape under the flange as it has a sharp grip, also to get it to grip the porcelain. It took some sweat as I had to push down quite hard, but it worked in the end!
Posted on Jul 16, 2012
I have same problem...I called Kohler and they offered me a $47 repair kit for the problem. (Probably plus shipping)...I told them no. Then they offered it to me for 25% discount. I told them no but that I was a builder and they could rest assuried I would not have this problem on the new house. Then they decided to send me the kit for free. We will see how it works. I was able to get the seat off by prying under both sides of the screw at once while turning the screw. (be careful not to break the toilet) It could then be fixed with some butterfly anchors but will wait the five days for the new anchors Kohler said they would send. Good luck with your problem.
Posted on Nov 02, 2009
2 Suggested Answers
SOURCE:
  • 28 Answers
SOURCE: I cannot replace my toilet
there is probly caps on the hinges or if not just directly underneath there should be a nut.
1. pop the caps off with a butterknife or whatever 2. get a flat head screwdriver to hold screw 3. use a socket to turn the nut underneath.
good luck
Posted on Nov 17, 2010
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
What is the name for those round parts on the underside of a toilet seat? What if one is broken?
You are going to have to replace the entire seat more than likely. Never seen one that you could replace those stand off's. Hope this helps!
Jun 12, 2015 | Kohler K-3386-0 Rialto one-piece...
I cannot replace my toilet seat on Kohler Rialto toilet. Please help.l
good luck
Nov 15, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I can't unscrew the bolts on my Kohler 3386 rialto toilet to replace the toilet seat.
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Dec 03, 2009 | Kohler K-3386-0 Rialto one-piece...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
10,953 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
