Krups is among one of the foremost names in coffeemakers, espresso
machines, blenders and toaster ovens. Krups also makes coffee bean
grinders, such as the Krups 203a. This portable, plug-in grinder has a
removable lid and bean grinder chamber. The blade on the Krups bean
grinder is fastened to the bottom of the grinder chamber. You may need
to replace the blade on your Krups 203. The Krups 203 comes with a
limited 1-year warranty, but the company recommends you send your
grinder to the company to make repairs. Order replacement parts for your
grinder by calling the Krups customer service department at
1-800-526-5377.
1 Unplug your Krups grinder from the wall.
2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
4 Use the pliers to turn the
plastic fastening nut to the left as you continue to hold the blade with
the channel locks. Once the plastic nut comes loose, twist it off by
hand and remove it, along with the plastic washer beneath it and the old
blade.
- 5 Set the new blade in place, and
replace the washer and nut. You will have to hold the new blade in place
with the channel locks as you tighten the securing nut.
Things You'll Need
- Cloth
- Safety gloves
- Channel locks
- Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
