Question about Yamaha HTR-6130 Receiver
I have a Zenith TV its has three ports in the rear video/audio left right my cable jumper run out tv to dvd to cable hook up/dvd is playing threw the 6130 but the TV won't play with video/audio jacks hook from tv to 6130 hook up for DTV/CBL.Is there another port on the 6130 that the TV plays threw?
Any audio/video in should work as long as your receiver is set to the same component as the cables are plugged into.
Posted on Mar 23, 2009
SOURCE:
How can I play a DVD on this TV?
Your DVD player probably has RCA outputs, commonly red (right audio), white (left audio) and yellow (video). A three-way cable connects the player to corresponding inputs on the rear of your TV.
A composite cable connects the output from a STB to the antenna input of the TV. That is not what you need for this application.
Dec 13, 2015 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Why can't we get the sound to work by hooking the DVD player directly to the tv?
The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
I hope this was Very Helpful and enjoy your DVD and TV!
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Dec 21, 2009 | JVC TH-M505 System
I do not find a vedio/audio(red, yellow, white)ports to connect to my DVD player. What is the alternative way to connect to my DVD player using this TV? Thanks
There are 5 RCA connectors on the back of this TV, (according to the manual). The lower three from left to right are Video in, Audio Left in, Audio Right in. There are also two RCA connectors above these that are the L/R audio outputs. Also, there is an S-Video input which I would recommend using instead of the RCA Video in. You'll still need to use the RCA inputs, but the S-Video will give you the best video connection into this monitor.
Oct 31, 2009 | Zenith C27A24T 27" TV
DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Jun 20, 2009 | Proscan 32LA30Q Television
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Yamaha HTR-6130 Receiver Logo
93 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
