We have a 95 chevy cavalier -- z24 -- misfire on 1 and 3 -- we have reaplce everything avery mechanic has suggested and still no luck -- no it may be the pcm -- any suggestions?
i have a 97 chevy cavalier i have changed the wires and hooked the wires up in a 4, 1 , 3, 2 sequence on the coil pack top to bottom. and a 1, 3, 4, 2 firing order but wont start... i have a 97 chevy cavalier i have changed the wires and hooked the wires up in a 4, 1 , 3, 2 sequence on the coil pack top to bottom. and a 1, 3, 4, 2 firing order but wont start...
You can't post conmments that contain an email address.
my friend is selling a 1997 z24 chevy calvalier manual with 148,000 miles. should i buy it for 200,dollars. its looks ok and runs ok what should i be looking out for before i buy it.?
try this : with the car in park start it, then from park move it down one. if it is reverse move it down another one, now that should be neutral, then the next one should always be drive
Code P0108 is a MAP (manifold absolute pressure) sensor error.
It is either mounter directly on the intake manifold, or on the firewall.
If it is on the intake, the o-ring may have failed.
If it is on the firewall, the rubber vacuum hose may have dry rotted or just have fallen off from either the sensor, or the intake manifold vacuum fitting.
