Everything works except the oven. The burners work fine as does the broiler. I thought it could be the oven heating element, but it will heats up to 285 Degrees. The stove has a flat top. One time the digital control panel displayed code F7. The model number is CHE9800BCE. Is this something I can do or should I call out a Maytag Repair Man?.
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
SOURCE: kenmore oven model#362.7122891 gas oven and broiler wont work
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Sorry not F7 but E7
How do I take it apart or get to the Touch Pad to clean it?
It is an electric range and oven.
