It shuts itself down before it even comes all the way on, i've held the f10 key while its powering up and it wont do anything, says it cant restore my operating system, system tools won't work, i dont know, are all these computers sold refurbished or used or what?
Yes, I use them for a year, and then they sell them.
Is there a problem?
OH, C'MON I'M JUST KIDDING!
1) Is the computer dirty inside?
The two major issues with desktop computer failure, is the computer is dirty inside; and Power Supply failure.
Post back in a Comment. We'll start here.
Be prepared for a 'Windy' tech. You may do so much reading, you'll feel like you are back in school.
(I explain in detail, as if you know absolutely nothing about your computer. Just the way I ride )
Regards,
joecoolvette
SOURCE: how can i do a
This indicates you have no resident restore partition on your hard disk drive. The easiest way is to put your Windows OS CD in the PC and startup. It should ask if you want to start from CD. Say yes and follow the instructions. You may need to press F2 or 10 to change the bootup sequence to start from the CD if it doen not do it automatically.
Thanks
SOURCE: Internet Exployer keeps crashing & I don't know what else to do.
We had a problem like this with one of our PCs and it was a very nasty virus that needed specialist help, they had to reload all the software. Suggest you get access to another PC and find out if it is a virus. Sorry!
SOURCE: computer wont turn on
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
SOURCE: the power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
