Question about Acu-Rite Acurite Wireless Weather Thermometer 604
I need a manual for the 00593W weather station. Please?
My clock keeps changing from central time (my time zone) to pacifc within 2 hours of being set correctly. Can you help?
  • 18,108 Answers
Push and hold the "-" button on the main unit until "P" displays on the screen. You'll now set the time zone so the system can automatically set the clock. The screen will begin cycling between the time zones. Push the "Set" button when the correct time zone appears.
Posted on Mar 10, 2013
SOURCE:
I have attempted to reset the time on my weather station for DST. Each time I do so it later resets itself to the original time. How can I move the time forward one hour and have it remain?
Does it have a setting for time zones? Clock change in Europe at 2:00am on Sunday.
If it resets, it sound like it is linked to a Time Server and that would be time zone set.
Google
make model manual
Mar 20, 2018 | Measuring Tools & Sensors
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
Why is the time on my weather station always 3 hours behind
You need to set up the correct time zone offset. For example, CST is -6; EST is -5. If daylight savings is active, time will be: CDT = -5; EDT = -4.
CST = Central Standard Time
EST = Eastern Standard Time
CDT = Central Daylight Time
and so on.
The Official NIST US Time
Aug 27, 2014 | Oregon Scientific WeatherStation...
Time reverts back 3 hours to DST
make sure unit is set for your "time zone" The adjustment button for pacific, central and eastern time zones is located on the back. Push the button until your specific time zone is reached.
Oct 29, 2011 | Eddie Bauer Wireless ClockThermometer
Mt atomic clock is always 2 hours slow no matter
How to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
Sep 26, 2009 | Acu-Rite Adagio Clock Radio
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
597 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
David Gust
ray gallant
ray gallant
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
