Dmm Benjamin Air Rifle Logo
Posted on Feb 21, 2009
I need a parts diagram for a benjamin sheridan model 397 air rifle. I especially need a section showing the trigger assembly in an exploded view.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6400
Points
17
You can find parts diagram in crossman web page under other help compleat dig with part#s
I have a Sheridan blue steak that need the tube assembly replaced or repaired. Is there a replacement for this. I have the part number from the handbook.
Contact the authorized repair facility in your area. It is listed in the back of the manual By Blue Streak I am assuming you have a C9 which is .20 caliber. They will direct you as to what can be done to fix or repair your air gun. I have a Benjamin Sheridan C9 Blue Streak from circa "95" when they still ad walnut stocks. I have shot maybe 20 pellets out of the 500 rounds in the red Diablo pellet box I bought with it. Paid a hefty $170 or so for it new. It is still like new. Bought a Beeman .177/.22 switch barrel barrel cocker. I hate all the pumping.
4helpful
How do i change my benjamin air rifle pump seal?
pyramidair.com has a seal kit. it also comes with a diagram. Benjamin and Sheridan air rifles do not have springs to propel the pellet. also never use vasalin. specifically for a Benjamin or Sheridan you need to use pelgun oil (also found at pyramideair.com). use pelgun oil because it is a non detergent fossil compound) the main intention is to condition the seals every 250 rounds. never use silicon based lube for this gun specifically. silicone lube is for spring air rifles such as break barrels.
5helpful
Need parts for a benjamin franklin air rifle moel number 317 177cal
http://www.crosman.com/airguns/service/repair
I couldn't find the model 317, But crosman bought benjamin, sheridan. Check it out.
397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
43helpful
5answers
Model 342 Benjamin Franklin 22 caliber air gun
I recently purchased a rebuild kit for my 342. I bought the kit from airgundepot. It was the kit for the
392 and I modified it a little. On the new plunger, you have to drill a hole in the center of it the same
size as the pin's smallest diameter. You can use all of the parts in this kit except for the small o-ring. I think it sold for about 39 dollars or so. My rifle was manufactured in 1972 and it fires like new.
112helpful
13answers
Top Dmm Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Dmm Boating Expert? Answer questions, earn points and help others
