Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
Bath tub spa will not shut off
My jacuzzi bath tub will not shut off. You press the button and it still runs. There is no access to the plug in switch and i cannot find a ground fault interrupter. Help!
  • katyss Mar 23, 2009
    I experienced the same problem on my jaccuzi tub a few months ago, but we were able to shut off power to the tub at the circuit box. We called a certfied repairman, but when he arrived, he said there is no access to the motors other than ripping out marble tile (and we don't know where exactly they are because we bought this 10 yr old house). So we sent him on his way ($80 later). We are getting ready to put the house up for sale and hope to resolve the issue without ripping out tiles (don't even know if I can find replacements). Could it possibly just be the button needs repairing?
  • albert getty
    albert getty May 11, 2010
    main breaker?
    Novelist:
  • 152 Answers
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
SOURCE:
How do you install a new on/off switch in a royal whirlpool bath?
The switch is located on the back of the pump. If you have access to the pump and you can see the tube coming out of the black box on top of the pump you might have a chance of changing it without pulling the tub, If you do not have access to the pump, one will have to be made or pull the tub for repairs. If the pump can be removed this might also make the repair go easier. The switch is available at most pool or spa stores. If you are uncertain about doing this repair call a Jacuzzi certified repair technician to do the job.
Jul 06, 2014 | Whirlpool ROYAL BRB826 Corner Tub, Jacuzzi...
My on off button quit working on my bath jacuzzi. I can go out to the garage and trip the breaker to turn it off and on. I used to be able to barely push it and it would come on or go off, now you can...
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Oct 25, 2013 | Jacuzzi Whirlpool Bath Tub Real EG85-969...
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Were is the starter switch located on corner jacuzzi tub
Depends on the make of your bath, alot of baths has a crome button on the corner of the bath, flush with the bath top. When you press this it pushes air through a hose and the pressure of the air hits a pressure switch on the motor which turns on the motor.
Mar 29, 2011 | Home
My tub does not want to stay running when i press the button, you have to hold the button down for it to work
the buttons on most of the tubes are pressurized air when u push it sounds like a bad button or hose it could even be the little air sylenoid that clicks on and of when the air is forced against it when u press the button 1st check the hoses for leaks 2nd remove hose and verify the button works
Jan 14, 2011 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Nov 30, 2009 | Jacuzzi Amiga, Soaking Bathtub - 9180
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
6,742 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
