Question about Minolta bizhub 200 All-In-One Printer
Bizhub 200 ADF parts
ADF table
  • Minolta Master
  • 6,850 Answers
Posted on Feb 16, 2015
SOURCE:
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 22, 2016 | Konica Minolta Bizhub C360
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Bizhub c300
microsoft wiondows xp professional version 2002 servicepack 3 software needed for model no M1005 LASERJET SCANNER PRINTER
Jul 02, 2013 | Office Equipment & Supplies
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Bizhub 200 touch screen is not working correctly
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 12, 2012 | Minolta bizhub 200 All-In-One Printer
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Black line appears in copying from Konica Bizhub 200
If the black line appears ONLY when copying and NOT when printing then you need to clean the adf strip glass. This is the thin strip of glass that is just to the left of the large original glass. Clean this glass very well with a soft cloth and glass cleaner. The line is caused by a small particle stuck to this strip of glass.
Jul 06, 2010 | Minolta Di3510f Bizhub Copier
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
I need a new ADF (automatic document feeder), where can I get one?
ADF can be bought from a dealer, it has a few cables that need removal so it is a little tricky, it is also a expensive part (approx Aus$200, why are you replacing it, are you sure you dont just need to clean feed rollers or there is also another common fault on these doc feeders, the left side hinge breaks( replace hinge)
here is the brother part number for the adf (complete), you will need to purchase from a autherised brother dealer -
LE8659001  DOCUMENT COVER LGL ASSY
Oct 17, 2007 | Brother MFC-8440 All-In-One Laser Printer
Minolta bizhub 200 All-In-One Printer Logo
49 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
